Did we ever establish who mothernorth is ? I really want to lol at him for this
Someone needs to learn how to play this game and understand that having a squad of people on one side does not make you a ****
Wash your mouth out and show yourself you useless git![]()
I would give anything for a button like Y on an xbox controller to switch to my pistol on PC. I've never, no matter what I can bind it too, successfully switched to my pistol when I've needed it.
the f2k is retardedly good. its like you die instantly to the first salvo every time - sometimes it feels like the first bullet does it. im not a whinger but that gun rankles me something rotten.
nerfing is not the answer, all it does it push the whine to a different gun / class. Eventually you end up with everything being rubbish. IMHO the weapons were more or less balanced within reason pre patch, there was / is no need to keep fiddling with them and pandering to the whims of people who cant over come obstacles.
I hope they reduce the power of the F2000 slightly, Tone the Flashlight down a good 50% and nerf that infrared-noobvision scope
Try using the mouse wheel, Seems the quickest way to me.
The amount of health packs and ammo crates I've thrown at people with this current method tells me its not the way forward, unless I could limit it to just cycling between rifle and pistol, even then id only cycle straight back to my bulletless gun![]()
It's not so much whinging but just fact that the F2000 wipes the floor against any other carbine, which puts someone who only plays 5hrs per wk at a huge disadvantage in a firefight. Bit unfair for the people who cant dedicate 5hrs per day to this game to be the canon fodder of the students and stay-at-home dads!
I much prefered BF2's unlock system where u actually put some thought into what u wanted to unlock and if u screwed up the choice, it was another 20,000 points till u could get another one! Having to rank up each gun is just annoying.
Dont bind it to cycling, bind it straight to the slot, so mwheel up is bound to your pistol mwheel down is bound to one of your gadgets or your main weapon. It doesnt matter how many times the wheel clicks up, it will still go to the pistol (not tried this in bf3 but it has worked in every other fps ive tried)
Is it true if you quit a game during play you lose all your points?
No. But you lose your end ribbons and bonuses.
