i lost 4% from bedtime at 11pm until now 7amvery impressed
That's very good.
Can you confirm what someone else above said that heavy screen time usage is only 4 hours?
I dumped Listen a couple of months ago and now use Podkicker. It's a lot better and free. Only downside is it doesn't sync with Google Reader
Thats a really good deal
Was a bit surprised when he offered the phone with that much discount I have to say. Made him triple check it was the galaxy nexus and not the nexus S or something. Fingers crossed this fix arrives soon or it will be going back!
Yeah it was louder after using AudioManager, seems to stay loud after un-installing too?
Theres tons of apps on the market that do that sort of thing...I think the wireless policy really needs an update, its good that it is on most of the time to save you data, but i think you should be able to setup a night time policy, you should also be able to set a data policy so that feeds update at 7am for example, with wireless coming on at 6:55. I found that with wireless on, you lose nearly 10% battery over night, with it off, around 4% as discovered previously.
Hopefully you'll get the right phone!
To be fair the volume issue isn't as bad as people are making out. I've had mine a week now (on giffgaff so using the O2 network) and i've only seen it happen a couple of times. Certainly not worth sending the phone back for.
Which app would you say is better AudioManager or Volume+?
