Is anyone else having trouble updating to the latest BIOS (running UEFI) from Windows (not tried the boot CD method yet), I keep getting an error...
The only thing I'm still not clear on is why there is a specific power adapter for EU which has "WWAN enabled" in the description, and another EU power adapter without that in the description...?
No idea on this one, just pick the default and it should be fine![]()
Just updated via Lenovo ThinkVantage tools fine from within Win 7, no issues, are you attempting the same or via other means?
Thinking of buying this as an early christmas present for my wife, who'll mainly be using it to write. What are your impressions of the keyboard and is the lenovo store the best place to buy? I was thinking of getting the i3 version with 2gb RAM and upgrading if necessary.
Very good keyboard in my humble opinion but a bit noisy. I have large hands but it still very comfortable. Trackpad is too small usable after you change the settings I guess.
Very business like look when brought with the black lid cover instead of the flashy red. Does your wife care for the looks or is it substance ??
I have the I3 2357m and if I am not wrong if you order now you will get the new 2367m processor. Very capable even with 2gb ram in it but I dropped in 4gb of crucial ram myself. Very easy to upgrade memory or the HDD. Just 3 screws to remove before you can access them.
What are your impressions of the keyboard.
If its lenovo branded, then it will work without bios mods. There is a fair selection - unless you've got any specific requirements such as linux support then any of them should be fine (As long as its Mini PCIE, which they pretty much all are) - just check they're not old 1.8mbit hsdpa cards.can someone recommend me a WWAN card which will work without modding the BIOS?
The clock rate goes up from 1.3 to 1.4 GHzYou're right, the processor on the site is now the 2367m. Is there any discernible difference?
I'm very snobby about keyboards, but the X121 is very good. Some of the keys are moved around a bit - but they're fairly logical and its quick to get used to the changes.
I'd rate is (nearly) as well as a "proper" thinkpad - which has the best keyboard on a laptop bar none. With the moved keys being my only complaint.
One thing which I know I would find incredibly annoying is the reversal of the Fn and Ctrl keys... I have never been able to understand this! I think I read somewhere that these can be swapped back in the BIOS... can anyone confirm this?
I'm not sure I would get on with the positioning of the trackpad buttons just below the keyboard. Has anyone had a problem with this?
Ah, this is standard for Lenovo / IBM. All my laptops are lenovo so it's just something I've become used to.
There is an option to swap in the bios - Config -> Keyboard and mouse
Trackpad under the keyboard don't bother me at all
I am getting on fine with mine, good build, light, not bulky...I am not so keen on the lid having no catch to get a hold of but that's it reallyI have almost managed to convince myself to go for it, but I still a few concerns that I want to investigate before I do.
(1) Whilst it has impressive specs, I am probably more concerned about the general usability. How is the build quality? Is it chunky and awkwardly shaped (e.g. battery bulge)? Is the quoted 1.5kg too heavy for the kind of portability I would expect from 11.6-incher? Is it reasonable to expect to use this as a standalone unit with no mouse?
I would say based on current use I will get 4-5 hours of battery from this thing no worries(2) Lenovo quote something ridiculous like 9 hours for estimated battery life. How long will this really last under normal circumstances (wireless browsing kind of thing)? How long for intensive usage (watching videos, gaming, etc)?
The ThinkVantage software is good, the power management is quite impressive and very tweakable, you can setup quite a lot in a custom profile etc(3) Does the pre-installed software do a good job of controlling the laptop hardware (e.g. underclock CPU/GPU to save power)? Any other "features" that owners find particularly useful or annoying?
Nope, only gets warm if doing a lot of hard disk work e.g. moving partitions around...in normal use it's nice and cool. I have not heard the fan going at all yet...(4) As the CPU is fairly powerful for such a small laptop, I imagine it can get pretty hot... does this mean it's very noisy?
£33 for 8GB posted with Crucial...and I don't think you void any warranty installing memory...no stickers to remove etc just 3 screws which already have signs of wear (just)(5) Does the 2GB RAM act as a bottleneck... is it work going for the 4GB? I know this can be added later, but I would probably get it pre-installed so I don't void the warranty, and I doubt it be significantly cheaper than £32.
If you want Linux to work with wifi then go with the intel version, if not the more expensive thinkpad version supports higher band wifi too(6) What further customisations should I make? Does the Centrino wireless module perform better than the standard? Is the branded carry pouch better quality/fit to warrant buying it over a generic one?
Just buy one with 2GB ram and the intel wifi and get that 15% reduction!If I'm still unsure I'll probably just put off the decision and accept that I might well be paying an extra 15%!
