I'd just like to point out that that is in fact a SCART cable you have there OP.
Nate
Nate
It's not though, it's clearly a EuroAV lead.
Mocking someone for shopping at poundland surely comes under
Yes Fyi, they are, Digital signal offers no degradation, it's either on, or not, Various places have compared this, i remember a few from when Monster cables became the latest Fad regarding cables, most places found a £2 cable performed the same as a 40 quid monster lead![]()
China tat, packing is right, wrong bleeding product in the bag.
tbh can you even get £1 HDMI cables in the UK
Not strictly true but a valid point none the less. Digital sends it's 1/0's as +5v for a 1 and 0v for a 0 and both voltages have small tolerances. If you get an unshielded cable with a Massive amount of EM interference it can induce "extra" voltage which can take your +5v/0v outside their tolerance and induce errors. However the amount of EM required means that 99% of cables will never be near a source of EM that powerful and therefore work exactly the same as the expensive cables. For example I work on Digital cables which have to be shielded as they're cm's away from a Radar.
