Look at the files' descriptions and sizes.
Heads up: if you change the value of fShadowDistance from the default value of 2500, shadows become very block for some reason. I change it from 2500 to 32000 (as per the DNA Extreme config) and it ruined the shadows cast by tree shadows in particular.
Neil, I don't think the Immersive Skyrim Thunder link is working in the op.
didnt see this on here so thought id post it testing it now
high res snow
http://www.skyrimnexus.com/downloads/file.php?id=1320
Yeah, i think it has been removed, probably uploaded an update under a differnet name or something.
I had a thunder storm earlier whilst playing- WOW, the sound was aswesome
EDIT- don't know if it is the same as this, i think it is- http://www.skyrimnexus.com/downloads/file.php?id=1702
Not a fan of this mod. You can clearly see that it's not seamless. That repetitive pattern on the snow would drive me crazy after about 1 minute.
Great thread this is. Thanks for collating all the info Neil. I probably check this thread 20 times a day.![]()
That looks good. I assume I would have to remove the 'no more blocky faces and detailed faces ' mods before using this?
Edit: Just read the description and it seems not. Nice, will install this later
