Beware.. OEM unlock will wipe your device
is there a way to select a custom ringtone?
Quick question about labs
If i swipe and hold from the side of the browser you got the option to select tabs how do i close the tabs? With the laps option off you usually swipe off the tabs to close it?![]()
Lift your finger on the popup key, rather than sliding it over further to select a tab.... then it will open the standard tab select screen where you can swipe away.
Has anyone else found Maps taking around 40% of battery usage over night? Only used 12% of total battery but it still seems odd.
