Sadly the IRNV nerf only plays into the hands of campers. If you move as a squad and take objectives (and actually try and win the round for your team) then it's now going to be much harder to spot the guy hiding in the plant pot whos been "defending" for the last 10 mins.
About attachments, I noticed a good few people using the heavy barrel, heres some numbers:
Heavy Barrel increases first bullet accuracy while aiming down a sight by 50% (sounds a lot but the first bullet is already pretty accurate anyway) while increasing spread while bursting by 50% and overall recoil by 20%.
Supressor also increases first bullet accuracy in the same way, by 50%, at the cost of decreasing accuracy while firing from the hip by 33.3% but doesn't increase the spread while bursting and actually reduces recoil by 10%.
Silencer + Foregrip + Scope of choice is the best combo for any automatic weapon.
SANTAAAAAA!!![]()
What you want to do, is use A & D keys to rotate the tale and W & S ascend / decend, then use the mouse SLOWLY, to tip the nose up or down, depending on if you want to go forward, or tip backward.
When you have the nose down, you’ll need to accelerate using W to keep yourself from divebombing in to the floor
Only move the mouse left or right if you want the chopper to tilt / bank left or right. I’d actually advise you to forget about the tilt, until you get the basic controls down.
To hover just keep the crosshairs on the horizontal 0 and control the altitude using W and S again. IIRC you don’t need to throttle up or down when hovering, but obviously if you hover low expect someone to shove an RPG your arse!
I sport the [OcUK] tag, although most people's battlelog names don't match their forum username, so I never recognise anyone.
EVH = dlorey, for example![]()
Hey there, I'll add you.
I'm Arctic_Pedo_Bear. Although I need to drop the final bit
I absolutely love guns like the SV98, it’s very powerful in the right hands and it brings me back to the oldem MoH:AA days when I used to mooch around with the German rifles, the bolt action reload is the main thing and then the sounds of the guns themselves – So good.
If you’ve spotted the enemy before you shot them then they will still be visible via the marker so when you reload and scope back at them yuo can fire again.
You should be aiming for one shot kills though. What I tend to do is spot them and team mates will then “loosen” them up a bit, so when you do hit them, if it’s not a head shot then it will be a kill shot because their health will be low.
That’s what sniping is all about![]()
Dont worry mate, your pretty safe when im sniping.What's all with everybody trying to kill me all of a sudden?![]()
Are you certain your internet connection is solid? Do you play any other online games at the moment and do they work fine?
You may not even notice a short internet drop-out during internet browsing, but it definitely would be the most probable cause of connection timeouts in some games.
Maybe try running pingtest.
Starting up The Smogsy server now
[TW]Fox;20698159 said:This is hugely frustrating. I basically can't play BF3 and nobody seems to know why![]()
Where did you get these figures from?
I'm not sure why so many people use silencers unless you are all playing hardcore??
I find in normal mode that the damage reduction from fitting a silencer far outweighs any benefit.
