FAO Icecold - And LiE and everyone else
It was legs again yesterday, so I lowered the weight, and did 3x8 after warming up with the bat and then some...Really tried to stick my bum out this time
Didn't work much though
Last week:
This week:
I just think i'm too lanky for proper squat form
Getting better, but still some problems.
1) Knees still come too far forward and you're not sitting back quite enough.
Seems like it's a hamstring problem. Stretch them, but with the stretches in the mobility thread as conventional ones are rubbish. Probably glutes too, but I'll get to them.
2) Tiny bit of extension in your back at the bottom of your reps.
You're doing this to hit depth. This is due to tightness in your posterior chain (glutes and hams).
3) Weak hips. Little glute recruitment and pretty unstable.
I assumed I mentioned it to you already, but do glute exercises and activation stuff. Glute bridges, pull throughs, bird dogs, walking/reverse lunges (not the type where you step forward). It looks like you don't fully grasp what I mean by using your glutes. Look at my video again and see what the top of my rep looks like; big glute contraction causing my hips to move forward rapidly. Essentially, you need to "air hump"
4) You need to be faster on the way up
5) Your core doesn't seem to be braced. This is partly why you're a little unstable. You need to be braced solid, you'll lose a lot of power with a wobbly core. How do you brace your core? Squeeze abs and simultaneously try to push your belly out with your diaphragm (think of your abs as a belt your pushing in to, it shouldn't actually move out at all). This is why we don't need to work on our abs in isolation as much as people tend to think, provided people can use their core properly...
Your knees aren't too bad, you just need to focus on them more.
Form looks good but when you come up, sometimes it just doesn't look "right", can't explain it
Tell you something that helped me to start with, and Rob showed me. Put two plates, the smallest possible (in my case 1.25kg) where your feet are positioned. And put your heels on those. It helps your feet stay completely still during the movement, and stops your heels coming off the ground. Helped me form greatly
I see a lot of people doing this, but it really isn't a good idea. It's masking a mobility problem and in some cases will only exacerbate the issue and either create imbalances or cause poor development of some muscles.
Back feels a bit better today. Spent like 30 minutes doing stretches and soft tissue work last night instead of the usual 10 or so. See how it feels tomorrow and maybe do some light DLs. Still not much chance of any new maxes next week though. Also haven't eaten since 9am, and have no appetite whatsoever, weird.
Be careful mate, keep the deadlifts very light if you do them. I wouldn't personally.
