Getting better, but still some problems.
1) Knees still come too far forward and you're not sitting back quite enough.
Seems like it's a hamstring problem. Stretch them, but with the stretches in the mobility thread as conventional ones are rubbish. Probably glutes too, but I'll get to them.
I'll look at the mobility thread, I did those stretches you mentioned the other day, not sure if they helped or not.
One thing to note, I do SLDL's before squats...Would this 'tighten' my hamstrings due to them being used and 'pumped'?...
2) Tiny bit of extension in your back at the bottom of your reps.
You're doing this to hit depth. This is due to tightness in your posterior chain (glutes and hams).
Good point...Is this where my lower back kind of gives in at the bottom? I feel thiss once I go past a certain point, it's purely so I go lower, so something isn't right.
I'll have to look up posterior chain tightness then, which sucks. If you know of any videos off the top of your head then link them and ill look today
3) Weak hips. Little glute recruitment and pretty unstable.
I assumed I mentioned it to you already, but do glute exercises and activation stuff. Glute bridges, pull throughs, bird dogs, walking/reverse lunges (not the type where you step forward). It looks like you don't fully grasp what I mean by using your glutes. Look at my video again and see what the top of my rep looks like; big glute contraction causing my hips to move forward rapidly. Essentially, you need to "air hump"
LiE pointed out about my lack of Glute use, so i'm defo going to be air humping next session.
Again, i'll have to look at the other things you mentioned...Should I be doing these on off days or? If I do all of this on the training day i'm going to end up being in there longer than I already am!
4) You need to be faster on the way up
Aye, air-hump it is
5) Your core doesn't seem to be braced. This is partly why you're a little unstable. You need to be braced solid, you'll lose a lot of power with a wobbly core. How do you brace your core? Squeeze abs and simultaneously try to push your belly out with your diaphragm (think of your abs as a belt your pushing in to, it shouldn't actually move out at all). This is why we don't need to work on our abs in isolation as much as people tend to think, provided people can use their core properly...
Thanks, makes sense now. I try to brace my core, but I think it's lacking due to me thinking about everything else that i'm supposed to be doing
Air-hump, push knees out, brace core, keep back tight, go deep. My lil brain can't keep up
Your knees aren't too bad, you just need to focus on them more.
Yeah, they were better this time, but definitely room to improve
Thank you for the lengthy post, it's highly appreciated...I think I have all these issues as they've never been pointed out before, due to me training on my own (I've never actually been to a gym)
I swear other people don't have this many issues
