Go changes icon
Which kernel and settings in SetCPU are you using? And is it stable
Edit*
NM, I don't really need any OCing. I've installed SpeedMod kernel K18 test3. Is very nice. One thing I like about speedmod is the lower screen brightness when low brightness values are being used, makes for reading text on white BGs way way easier in the dark in bed and also helps battery.
icon yes not the size of it in the dock tho.. unless they have updated it - and i wouldn't be surprised if they did since the last time i've tried it was like 2-3 months ago![]()
Help please guys
I got my wife this phone about 6 months ago and its the best phone I have ever seen or used (and its hers) Boo Hoo
anyway to cut a long story short in the last 3 days she has been telling me that when she makes a call noting happens
she presses the dialler button to anyone she wants to ring and the phone looks like it is ringing but it is not
and the phone she trys to ring does not ring at all and has no missed call etc
its the same with texts it just wont send them saying cannot send at this time (or words to that effect)
however on all 3 days that this has been happening if I switch the phone off and restart it - the thing works fine
but its happening everyday now and she should not have to reboot the phone every time she wants to call or text some one
does anyone have any ideas as to what might causing this
having done an extensive google search I cannot find anything about this
so would appreciate any help at all (its on contract with Orange) 24 months and about 6 months into that contract
thanks Chris
Signal ok each time this happens?
I'm on Orange and mine started doing this occasionally when i started using Orange & T-mobile networks together
Not 100% sure about the signal as I just rebooted it and it worked fine than the day after it does it again but next time it does it I will check out what the signal is like
it is as though another program is blocking it or something
looking at the phone while it does this it actually looks like its ringing with the calling lights lit up etc but no sound and it is not ringing the other phone and also wont send texts
restart it and it works again??
Yeah that's a bit cheeseI'm on 50% after 13hours at the moment.
Where did you get better battery stats?
