****The Official Samsung Galaxy S II Thread***
Underclock and undervolting helps loads, 67% after 10 hours and 2houra screen on with about 5hours on 3g as well!
just tried ICS launcher. how do i set the number of home screens from 5 to 1?
i wonder how ICS official will be on the sgs2, the 3 soft keys will be pointless.
At the moment it looks like normal touchwiz & the menu's looking ICS. The 3 soft keys won't be there, they are only for phones without hardware buttons.
I won't have them.
And my USB cable will not transfer data from my SGS2 anymore. SGS2 doesn't even say its connected, only charges, doesn't ask to make it able to transfer data, wanted to put the checkROM on it too :(
If you are rooted you can use samba fileshare from the market to transfer over wifi. Have you tried checking usb debugging in settings > applications > development I find that way to be more reliable than the MTP way.
Sorry for double post :E
I was using an MIUI rom and couldn't see it anywhere :(
It's fixed now though, on CheckROM :).
That doesn't sound that amazing to me.
It doesn't to me either, i can go a full 24hr from pulling off charge and have about 40-50% left. I use my phone a lot, emails, sync on 24/7, 3g/wifi always active so my data is constantly syncing, and then tweeting/facebook on the way home from university. However i don't ring people ;)
It is considering its running the latest rom, kernel and modem and the kind of usage I have given it for those hours of screen on time.
Was that straight off the bat?
Im on the most recent Niyah Kernal, and most recent CheckROM.
Haven't had a chance to check the life on this yet, my previous comment was coming from a stock that I put on as i was having issues.
Will update you when i have done a few days :D
What is your screen on time? Also screenshot of the battery usage meter? Thiabgives valuable info that can help others. Mine has been posted before, same usage as ever.
I will after the next 2 days, needs to get used to its charging pattern to show a proper reading right? It's unfair otherwise.
Also are you using the Extended Battery?
Yes, my phone is my "netbook" on a daily basis now so yeah, it kind of gets used quite heavily when it is used.
So. How do I get good quality wallpapers? I have images on my computer that are crystal clear. They are the correct size for the phone and when I put them on my phone they are slightly blurry. I don't geddit.
