- 12 May 2011
- UK
Just ordered mine, hope there's no imperfections
Hi I installed the new drivers when I could not get anything on the Hazro had to connect my old monitor to the GPX card it has two Dual-link DVI ports still no joy. I have tried both DVI ports with the Hazro cant see nothing I can only see the BIOS on my old monitor when it is connected When I first powered on the blue LED was flashing then turned solid blue as pc booted the led screen seemed to go a bit brighter but no picture. I then connected my old NEC Multisync to the other DVI connector on pc got windows desktop on that. The device manager on win 7 says Generic non-pnp monitor for the hazro, I made sure win 7 is up to date, I did a clean install of the latest Ge-Force driver 285.62 then played around with the desktop resolution managed to get a fuzzy desktop repeated 4 times on left side and 4 times on right side at a setting of 1280 x720 (I know this is a incorrect setting) my old NEC is 1600x1200 working Ok. Do you think the monitor is faulty as win7 sees it as a non-pnp monitor? my graphic card spec has dual-link DVI x2 max resolution of 2560x1600 so should be up to the job can you please help me?
)I think one of the major problems I had initially was the fact that I was connecting 2 monitors, and Windows kept assuming that my original (old) monitor was the primary. If I recall correctly, what eventually happened was that I had to make sure that the port I was connecting to on the graphics card was the Dual-DVI one, and only boot up with the Hazro connected and switched on.
This is exactly what happened to me, it took me about an hour to sort it out. I've never had a problem using any other monitors in a dual setup but the Hazro seems fussy for some reason, whether it's the monitor or a problem with DVI + DUAL-DVI setups I don't know![]()
I have removed all Ge-force drivers with Drive Sweeper reset my BIOS removed internet connection rebooted to check no Ge-force drivers were installed using old monitor then reinstalled the latest Ge-force drivers 285.62 restarted pc with just the Hazro connected blank screen still I could hear Win 7 had booted so left for several minutes but no joy
I am waiting for answers from Ocuk & Hazro is it my setup or do I have a faulty Hazro?So let me get this straight, if you have JUST the Hazro connected, do you see bios, etc... and then it turns off once you get into Windows? If that's the case I'd say it's down to your Windows installation. If it never turns on it's either a dodgy dual-dvi cable (rare) or faulty monitor...
These are pre-calibrated by Hazro so you have to assume they had the monitors working at some point...
I just have the Hazro connected blue light flashing I then start the pc I cant see BIOS then blue light goes steady screen is on then as its a bit brighter I can hear win 7 start sound but nothing on Hazro I am using the Dual-link that came with monitor. Should I DSR or RMA it what is my best option?
So far..
Glass advantages: Easier to clean(?) and might look more classy depending on your personal preferences.
Glass disadvantages: Might end up in a million pieces during transport, might slide, might have dust trapped underneath, adds reflections
(and no it doesn't improve the image quality - not with an monitor that's already glossy in the first place)
Under the distance selling regulations you should always be able to return the product within the first 7 days, iirc you don't even have to mention why. It's simply your right to do so (costs to send it back are your own).
The ATI might proof itself to be problematic, there are plenty of people with a 5xxx card that experience problems and plenty that don't (my 5870 Mobility is fine with it).
