*** The 2011 Gym Rats Thread ***
Status
Not open for further replies.
Man of Honour
27 Sep 2004
Glasgow
What are the above two? :o
The first one is Close Grip Bench Press which is as the name suggests where you're holding the bar in a very close grip, as a guess when I do it there's approximately 1-2" between the knuckles on either hand. However that's just a spot that works for me, it may be you need to go wider or a bit narrower - it should really work your triceps and your elbows should be relatively "locked in" so they're not moving much (i.e. outwards) and losing the tension or at least that's what I believe is the way to do it.
French press - probably easiest to look at this video, I'm not qualified to offer an opinion on whether the form is spot on but it ought to give you an idea to start with.
29 Aug 2005
Went and had a look at Virgin Active, my god what a pile of ****e for £60 a month each! Thats not me being a snob it really was bad, aging rusting equipment with next to no plates for the squat rack and they also had separate swimming pools/sauna so I wouldn't be able to be with my girlfriend.:rolleyes:
Fitness First is to far away for us, so we will be going back to the David Lloyd which I was very impressed with when we originally went there. I have also discovered they have revamped the weights area with £200,000 :eek: worth of new updated equipment and more 25 kilo plates :cool:.
LiE
LiE
Caporegime
2 Aug 2005
Milton Keynes
Damn I feel for you Tank, I'm spoilt for choice in Milton Keynes for gyms. David Lloyd's is so damn pricey for a solo membership I couldn't bring myself to consider it. It does look nice though and wouldn't get any bicep monkeys.
Man of Honour
6 Apr 2007
Yeah but.. I seem to have permanently 'twinged' my elbow since that one time I did skullcrushers (with too much weight probably).
And it flares up on the above exercises, no doubt once I switch my routite and go tricep pulldowns/dips etc it'll be worse.
Any suggestions?
By the way I use elbow straps to compress the elbows now during shoulder press.
Get it looked at by a physio.
HOWEVER, problems in elbows tend to arise from problems in shoulders...
Physio session today, and after various pulling, tugging and bending of my foot/ankle/shin (yes, bending my shin :eek:) my ankle made some sickening crunching sounds which were apparently good news. My tendons are still junky from an almost two year old sprain, which is apparently common.
Told him about the pains in my shoulders and it seems I've developed bicep tendinitis in the proximal head. It's a pretty complex picture, but tight pec minor is turning off supraspinatus (and trap, lat and teres minor to some extent) so my bicep and tricep need to kick in to pull my arm in to the socket for stability. Also, in an ironic twist, the soft tissue work I've been doing has caused the tendon to hypertrophy which irritates the grove it runs through.
Hopefully this solves my benching problems!
Deadlift day tomorrow, and I'm planning on a big Christmas rack pull :cool:
29 Aug 2005
What I love is you're fixed to a contract **** or bust, so they will struggle to get rid of me if I load a machine with to much weight (in their opinion). :D
Man of Honour
5 Jun 2003
Falling...
I go to a David Lloyd and I have to report you do get bicep monkeys :( but the equipment is good. I can afford it as far as I'm concerned as I like the facilities. Hopefully I'll get my gf to join so we can get a cheaper rate next year
Caporegime
7 Nov 2004
Buckinghamshire
Thanks matey, much appreciated.
How you've described the CGBP, sounds eefectively like a skull crusher :o...If your elbows are keeping in? :)
Status
