Hi Guys,
Was just reading the thread regarding the remap of the 335i which i must say has tempted me!
It got me thinking about the problem i'm having with my lights atm - and i was wondering if anyone could shed some light on the problem i'm having!
When i bought the car, it had blue lights both on the main beam and the angel eyes (2 rings).
About 2 months ago the angel eyes went on one side. I took out the faulty one which i realised was an aftermarket set (the ultra bright ones that you can buy on ebay for £40-50) - so i bought a set of identical ones which i fitted and they didn't work. I took the car to a local place where they fit these all day (at a cost of £170 for what is essentially the same thing!) and they didn't work either - the guy suggested it was either a fuse or a wiring problem.
I had the turbos changed at BMW, and i mentioned the problem to them - but the guy even said i would be spending a lot of money for them to investigate the problem and fix it, it wasn't covered on warranty, and that i was fine to just use the normal headlights without the rings
So i'm not sure where to go from here - the fuses seem ok, but i don't wanna be spending a lot of money on this.
Any help would be much appreciated - i think i have explained the problem well enough!
Thanks in advance guys
