Man of Honour
- 5 Jun 2003
- Falling...
I read in an interview Hoy said that his thighs are only 26 inches around the thickest part.
Is that it?? Just shows how being lean and muscular helps.
Chaps, how is my current work out looking?
Bear in mind I'm 23stone (down from 26 since September)
Going to the gym 4 times a week, with a 40 minute brisk morning walk 5 days a week.
At the gym I combine cardio and weights, at this stage is that OK?
Obviously my main concern is weight loss but I want to avoid loose skin, and just get progressively fitter along the way.
Gym workout comprises of:
4x 12 sit ups.
3x 12 of single arm rows - 10kg.
3x 12 of lunges - 20kg
3x 12 lateral pull down (I don't know what the weight is, just says 12)
3x 12 (can only describe it as a sort of sitting down bench-press?) sorry I don't know the actual name!)
2x 500m row
10 minute cycle
Any extra help would be great as the more weight I lose, the more I want to refine my exercise.
4x 12 sit ups.
2x 500m row
10 minute cycle
Jogging at 23stone? No ta.Unless you want knee replacement ops before you're 45
Defo look into swimming though.
As for recommending a load of stronglifts for someone who is primarily concerned about fat loss.. not everyone wants to get big UE. Many want to get small![]()
It might be worth getting a gait analysis at a decent running shop if you're going to be running regularly but as Dj_Jestar says you're probably better off without shoes for much of stronglifts. Good running shoes and good shoes for weightlifting are mutually exclusive pretty much, what makes a shoe good for running is generally cushioning and flexibility which absolutely sucks for providing a good platform for weightlifting, what makes a good platform for weightlifting is inflexibility and minimal compression which sucks for running.
Hmm, thanks.
Different shoes isn't really an option, my current routine is sort of 15 mins on the treadmill followed by the SL5x5 routine (then a cool down on the exercise bike). As it's only 15 mins running on a slightly cushioned machine, do you think something like the Vivo Barefoot shoes would be okay?
To be honest I've been using Nike court shuttle shoes at the gym and haven't been having any issues apart from them not wanting to run in a straight line.
Booked an hour with a trainer at the gym in a few days, any more ideas you lot can recommend on top of that?
Edit: see my posts up a bit for it to make a bit more sense.
