To be honest, from your story it's hard to know if there even was a problem with the RAM.
I bet they are looking at the free ram after widows has cached everything not how much ram is used by stuff
That's the sort of thing I'm thinking of, though I don't know all the terminology as I don't use a modern version of windows. Prefetch or something like that? Turn that off, kill all processes you don't think are necessary, etc. then marvel at everything taking twice as long to start. Top tip for free RAM - run MS DOS 7! The RAM footprint is tiny!
No need to turn anything off it makes windows faster, if apps need the cache the data is dumped and given to the app.
My uncle jim does any surgery you want for a tenner if you ever need it![]()
I agree though, the technical knowledge of most of our staff is just shocking. I had to make up a usb stick of diagnostic utilities because we don't have anything of the sort given to us. Some people have their laptops sent off for weeks when they could've just run mbam instore.
U clearly know nothing too, I would open the memory hatch at the bottom and see what sticks are in there or just use cpuz. Sounds like to me the 2gb stick has been removed.
And void the warranty good one idiot.
No you won't idiot. Unless there was a void if removed sticker over the hatch. You know less than the purple shirt and have nerv to rip it out of them looool
Only come here for the looools!No you won't idiot. Unless there was a void if removed sticker over the hatch. You know less than the purple shirt and have nerv to rip it out of them looool
You're.
You're.
why dont you check the bios? how much ram does it show? cpuz? sisoft sandra?
My parents went into a spicy high street electronics store to buy a tv, the bloke said thwy didn't want to buy a 1080p 40" toshiba LED cause it uses too much power and that a 51" 720p samsung plasma would be better because it was more efficient.
I have checked the bios showed 3gb this I also showed mr purple. Like I said they said it was fine when clearly something was not
Should have got a mac. lol
