Permabanned
- 15 Nov 2008
Hi
Having done my first WC build recently, I have done a lot of the research you are currently doing, obviously I'm no expert, but from what I found
Theres no real benefit for going for 2 loops, unless its aesthetics and youre wanting 2 different colour liquids, the pumps are powerful enough nowadays to be able to handle all things in one loop, and the temp difference isnt worth the extra outlay
For your case, Id highly recommend getting one which is designed to take WCing from the off, and doesnt need modding, as its a) easier and b) cheaper
The angle fittings (45&90) are here
And yes, Cleecoos spec is very good starting point, you can obv customise it as you like, eg the equivalent CPU block would be this
I doubt theyd be the best either tbh, Scythe Gentle Typhoons are whats generally recommended, though I went for Akasa Apache Blacks personally, start with a decent fan, you can always add an LED strip behind them or something to give you the visual effect after
