I really should complete the Co-op missions; Only done 2 of them!
Struggling with any motivation to at the moment though!2 more than me!
Now my daughter is better I can start gaming againStruggling with any motivation to at the moment though!
if you have a big monitor 1080p resolutions and above, play with the mini-map set to big.
I have some of the same issues , only got to rank 24 after about 70 hours. There are masses of cheaters on there but there are some good players who know the maps and can rack up a score.
The big scores seem to come from good team work, 100 per revive if you're medic + health for everyone that boost off it. Same with the ammo in support.
Max I've had is around 6,000 but that was a very long round, nearly 2 hours for 500 tickets.
AD
As for flying ... find a quiet 8-16 player server that's 2 player start and spend some time crashing. I've been trying to learn jets and I found 2-6 players fine but you often get some booster in their just taking easy kills who has all the unlocks or someone in the AA being a nuisance to get the unlocks for that.
AD
one thing in BC2 you had an acend key and down key which I had set the same as my crouch (down) and up (jump) this isnt an option anymore ? which is strange.1. Sorry cant really help here, could you post a video of your gameplay?
2. Try and mess around with the network slider? You should have a good ping so try it near to the left.
3. Thats odd, ASSUMING you dont have a game controller plugged in or have very high mouse sensitivity set.
4. Search for "1 player" servers to practice flying.
Also, what computer setup do you have, BF3 like its hardware?
Lastly, BF3 like BF2 is all about "situational awareness" and steady slow play (unless its Operation Metro) if you have a big monitor 1080p resolutions and above, play with the mini-map set to big.
Or, if you're on a budget, practise with the T-UGS or MAV and a personal defence weapon, I like the PP-2000
Then after press n to zoom out![]()
Obviously inflammatory? After a post which jokingly called normal players noobs? This makes me arrogant and childish?
Get over yourself.
I have now edited the post in question to be more suitable, link.
Help !!!
So frustrated with this game!!
My three main issues are this:
1/I die 2-3+ times my kills no matter what class /map etc. If I play the game stealthy I end up with 100 points and come last....
2/In a 1 to 1 situation I always loose no matter what combo of kit I use im Colenel 6 so have most kit.
3/I cant fly a helicopter as it goes left or right almost instantly and you cant go on a server on your own so how can you practice ?
I don't consider myself a bad player I was ranked 64 in the world at one point on UT2k4 I know its very different but ...like I said I dont consider myself bad at shooters ????
Another thing for me is I use the arrow keys I've never been able to get on with wasd not matter how many times ive tried.
Connection is 50Mb Virgin so should'nt have a problem there ?
Awesome rounds with MTA99, DG, FUNKY SPIDER, MONK e.t.c on the ukcs server![]()
, I was up in this building with my back against a wall slightly to the right of a cappable flag icon. The game spawned an enemy behind me, partly in open space and partly through the wall! I get random slowdowns when playing online, any fixes?
