I think it's for retards that don't know that less than 5 goals means 4 or less, rather than 5 or less.
OcUK. Where you'll make one mistake, and then forever be classed as a "Retard".
Over 5.5 goals is just a less convoluted way of saying 6 goals or more, and under 5.5 goals 5 goals or less.
I think if I manage to make £100 from the £12 then I will split the pot between two different bets, rather then all in.
Are you just doing Football bets? And are you sticking to 1.02 bets or are you doing others?
That is based on around 12 betsI like the inplay function and yes a few are over the 1.02 marker (1.08 being highest)
Most bets have come from inplay when a match is in the second half, it seems slightly less risky then before it starts.
