I bought a 2000mAh battery from mobilefun.co.uk, I charged up while it was turned off to 100%. At first it was fine, then it randomly started resetting itself when it was idle (Twice in 3 hours), turning off and back on again when sitting on my desk. Left it overnight with no apps running and the battery drained from 70% to 20%, so I took the battery out and put the old 1 back in, turned it back on 2 minutes later, it freezes, the screen goes darker, lines appear across it (Red, green and blue, small vertical lines covering the screen), take the battery out since it won't turn off, then it won't turn back on again. Leave it for 5 minutes and it turns back on but then locks up 2 minutes later again. Do this multiple times, each time it freezes when trying to do anything at all (Even reset it). Do a factory reset holding the phone buttons down, 2 minutes later after turning on, it freezes again, lines across the screen.
I don't get this at all, it was fine before I put the new battery in. Can a new battery really screw the phone up? I don't understand.
Haven't rooted, default ROM.
