Foregrip
The Foregrip  is for players who who are in close combat and highly mobile fighting  situations. It reduces the horizontal recoil forces that make  maintaining a consistant aim on target difficult, however it makes aimed  shots more difficult.
- +34% reduction in horizontal recoil (adjust based on gun)
- -20% penalty to base accuracy when aimed
Bipod
The Bipod  is for Players who wish to setup a position and hold it against the  enemy, or make long range shots effectively. When deployed recoil and  dispersion are substantially reduced and scope sway is eliminated  (except under suppression).
- +Reduction in horizontal and vertical recoil (% depends on gun type)
- +Reduction in dispersion (% depends on gun type/ammo type)
- -Has to be setup to get the benefit
Suppressor
The Suppressor  is for players who are mostly focused on Stealth. It uses low velocity  rounds, which means better stealth at the cost of reduced range. The  Suppressor adds bulk to a weapon due to its size, making firing from the  hip more difficult, though a high quality Suppressor provides a small  aimed accuracy bonus and reduces the muzzle rise when firing.
- +Does not appear on minimap when firing.
- +Reduces sound and visual muzzle signature
- -Reduced range for both min and max, damage stays the same.
- -50% penalty to base accuracy from the hip
- +25% bonus to base accuracy when aimed
- +10% reduced vertical recoil
Heavy Barrel
The Heavy Barrel  is for players who are focused on Accurate Aimed fire. It uses high  velocity rounds, which means the bullet drop is reduced and the max  range of the weapon is increased at the cost of an increase in auto fire  dispersion. The Heavy Barrel adds bulk to a weapon due to its weight,  making firing from the hip more difficult, though it gives a substantial  increase in aimed accuracy bonus.
- +Increased maximum range, damage stays the same.
- -25% increased dispersion per shot
- +50% bonus to base accuracy when aimed
- -25% penalty to base accuracy from the hip
Flash Suppressor
The Flash Suppressor  is for players who want some additional Stealth, without the range and  accuracy penalties of a Suppressor. It works as a recoil compensator,  reducing recoil, though it adds a slight bit of bulk making firing from  the hip more difficult.
- +Reduces visual muzzle signature
- +20% reduced vertical recoil
- -20% penalty to base accuracy from the hip
Target Pointer
The  Target Pointer is for players who want to run and gun from the hip. The  laser is visible, making the user more visibile to other combatants and  thus less Stealthy.
- -Visible Laser
- +Laser can dazzle opponents
- +33% increase in base accuracy from the hip
