Although on paper this idea looks good but from many years of gambling experience i can tell you it's not worth it.If you want to have a chance to make decent cash fast start with £10 or so every weekend do only 4 times a month max then try get 6-10 bets correct in a row that you think are good by rolling over the winnings onto the next.
The idea i just said may not be brilliant but it can work and least you've only started with £10.
The only way to make the OP idea work good is to have large sums of cash but even then you are completely mad to lay like £10,000 on a bet or so to get 0.02% return.
Goodluck though hope it works.
