ps- when the big ios overhaul comes who trusts an apple without Jobs ruthless appraisal technique.
This work ethic will remain, no doubt about it.
That looks much more like my Android phone than my iPhone. In which case, why not just buy Android if page upon page of square apps are not your thing?What?
My iPhone is great because I can make it look like an Android device.
But Apple software is so great that you have to Jaibreak and modify it to look like software you don't like? I was under the impression that it was easier to create and release an Android App, but I have never made either so not in the best position to say that as fact. I could google it, but perhaps the search results will be bias.Simple... I don't like the Android software. It's horrible to use and it's horrible to develop apps for.
Just a quick FYI, the Samsung Galaxy Nexus doesn't have an SD card slot. (Yes, I know it's only 1 phone out of dozens of Android handsets, but it's now Google's official flagship model)
I don't understand this obsession with trying to make iOS look and behave like something it's not. Maybe it's the entitlement, me me me thing.
iOS works well, is intuitive and assuming you don't jailbreak about as secure as mobile operating systems get.
edit: The problem with Android is that there are many crap, many average, and many good phones. I can only compare the SGS2 (rated as one of the best) to my iPhone 4, and in my opinion the SGS2 is significantly better. Sure it does nor win within every single area, but overall it is the better software for me.
I have never had an SD or micro-SD card fail on me, but my 3G connection regularly disappears. The cloud is only of any use when it is available. For holidays, travelling on the tube etc it is about as much use as a 3 legged greyhound. SD cards are cheap, faster than the cloud, and you can buy as many as you like.another reason to leave behind SD cards....
apples roadmap does not include removable media.
thats what the cloud was created for. if you want a file it will be on the cloud for you, not on some flakey 16Gb SD card you just lost down the back of your sofa.
it's where they are headed and if they can get it right, it will be the way things go for most tech.
apple are as popular as they are because they have removed a lot of choice from computing and as such removed a lot of headaches.
What?
