The lightning and twin frozr III are the same board and cooler.. So yeh its bigger than a reference card.
Eh? How come the reviews are saying the Lightning has a depth of ~4cm, and the Twin Frozr III has a depth of ~6cm? I dont think you understand what I'm getting at. If the Lightning is the same thickness as the PCI bracket then it'll fit in my case with the soundcard below it, no problem - if the TFIII is 2cm thicker than the Lightning, it WONT fit...if that makes sense.
