Anyone here could do that given enough time,
Quake Done Quick from a few years back was entertaining.
Last time this got posted here somebody claimed that it wasn't a true 100% run (claiming some monsters hadn't been killed), until I asked them for examples which I was then able to explain how they got killed (in highly optimised runs like this, often you don't waste time killing all monsters in a room on the first pass if you are going to return through there later - you can also incite fights between the monsters so they kill each other).
Make sure you check out other QDQ runs that don't go for 100% kills and secrets, instead of 52mins it will take about 10mins with some much more extreme shortcuts.
This is the case for 99% of activities in the world ever.
I disagree.
I don't think anyone could have come up with the theory of relativity given enough time. I don't think anyone can play Brahms' piano concertos perfectly given enough time. I don't think anyone could have written The Beatles' music given enough time.
^insane!
terrible comparisons
I disagree.
