Caporegime
- 13 May 2003
- Warwickshire
Ribble is definately a good shout.
The only other option worth considering is Planet X Pro Carbon with SRAM Rival.
That double tap gear change is complete fail imho
.Ribble is definately a good shout.
.That double tap gear change is complete fail imho.
[DOD]Asprilla;21045612 said:It's how they do it on the continent. Makes for much better cable routing.
How does it make a different to the cable routing?
just the difference on which side the cable attaches to a side-pull brake?
Does anyone have a Respro Hump backpack cover? I quite like the look of the P15 chevron.
ok,
so I've clicked buy button...
ended up with :
Ribble New Sportive Carbon Road Frame L (55cm C to top)
Ribble New Sportive Racing Carbon Road Forks 1 1/8" ITS
Ribble Headset Branded Ribble 1 1/8" Hidden (ITS) 45 x 45
Shimano 105 (5700) Black 10 Spd Double Groupset
Shimano 105 5700 BB Cups (105 10 Double/Triple) Eng
Shimano 105 Black 5700 Brakes
Shimano 10 Spd 105 5700 Cassette 12-27
Shimano 10 Spd 5701 105 Chain
Shimano 105 Black Dbl 5750 10 Chainset Compact 175 34/50
Shimano 105 Black (5700) 10 Dbl Fr Gear Braze-on
Shimano 105 Black (5700) 10 Spd Rear Gear Short (SS)
Shimano STI Levers 105 Black 5700 with cables Double
Rodi Pr Whls Airline Evo Clinchers White 8/9/10 Shim
ITM Triango Carbon (31.8) Bars Black 44cm
ITM Triango Carbon (31.8) Stem Black 100mm
CSN Superleggera K10 Saddle Black
ITM Alutech 7075 Carbon Seatpillar White 31.6 350mm
Vittoria Rubino 3 Rigid Tyre White/Black 700x23mm
Prorace Inner Tube 700x18/25 LV52mm
I do hope it will all work![]()
and most important, I will be happy for a loooong while![]()
Make sure you take a few pics of that bad boy when you get it and put them in the 'show of your bike thread'.
Cold this morning. And I think I've broken my toe :s.
How have you managed that? Cycling-related?![]()
