GTX680 to arrive at the end of February!
Man of Honour
13 Oct 2006
If theres any truth in that and its 768 shader @ 780MHz then it would be about 7970 performance, not very exciting but it wouldn't be the proper top end card.
OP
5 Sep 2011
Nottingham, UK
no, if you read the article, the gtx680 will be around the power as the 7970, but with the 7970 having a gig more ram, it should have a slightly higher threshold for AA and may give better framerates!
11 Oct 2007
2gb is the sweet spot, with a 512bit bus it's 2gb or 4gb, 2gb is a winner for bf3 high performance @ high texture and AA settings. 1.5gb just falls short and I am not aware of any games peaking 2gb as yet, even at higher resolutions.
bee
bee
22 Jul 2005
2gb is enough for me to run 5760 x 1080 easily enough so i don't see any issue with that amount of vram
25 Jan 2006
Birmingham
Oh dear, flagship single core card, and only performance to equal 7970? What a disappointment... Imagine if the price was higher than a 7970 too, would be pretty funny. :)
But it is only a rumour.
10 Feb 2007
How did you calculate that when the 7970 is only 20% faster than the 512 shader GTX580? Even without any optimisations (which there most probably will be) a 768 shader GTX580 should easily beat the 7970.
On the basis that the 7970 has approx 30% more shaders than the 6970, and that the GTX680/780 may have 50% more than the GTX580, and that the GTX580 was ~15% faster than the 6970 to start with, what do you really think will be fastest?
2GB vs 3GB will only make a difference when >2GB is needed. At the moment breaching 2GB is unlikely at most reasonablle resolutions. Why is AMD soon to launch 1.5GB 7970/7950's if that ammount of VRAM is insufficient to run games at high res?
Man of Honour
13 Oct 2006
It won't be the nVidia flagship card - it will be basically like the 560Ti in terms of how it stacks up in the Kepler range.
