- 6 Jan 2011
- Stoke on Trent
Hi Just needing to check that a Kuhler 620 or the intel cooler will fit inside the antec 1200 case . Does anyone have a closed watercooler set up , Or any that do ?
IM concerned that The radiator with its reservoir moulded lump will not fit on the top 120mm exhaust fan , because of the top fan , Also the second one lower rear 120mm sits right on top of the graphics card .
If nt is there an alternative , or should I look for a full W/C kit can recommend .
Many thanks .
Many thanks .
