Head max on D5 Vario
Probably dumb question time, but is ambient the lowest temp you could achieve using a custom loop, eaxample even if i stuck 4x480 rads in a loop if my room temp is 25 degress i could never see a lesser temp than this unless i used a chiller???
No turning back now mate ordered some fittings of the MM and a couple of other bits from various places. Also time to get a new dremel me thinks.
Time for a dremel spec me thread LOL
I'm more low tech, I've got a dremel but prefer to use a Jigsaw with metal cutting blades and a hacksaw for the finer work :)
