 - 23 Nov 2009
 - North Leicestershire
You have to be gentle and buy lots of spares![]()
Maybe i'll break out the 6 inch grinder for the bigger work, the plastic mods will be good with a dremel i presume
Hot water, once all the gunk is out I then just give it a quick rinse with DI
can i just attach a barb, hose and funnel then just run my hot tap water through the rad then once clean flush a few times with distilled
yes, that's what I meant![]()
brill cheers mate, i'm just running through some list and bullet points, don't want to **** it up LOL
better to ask, always!![]()
Go to your local chemist and ask for purified water
purified water = distilled, use it to fill the loop
Is it ok to just have 4 fans in pull mode, I won't be able to get 4 underneath the rad for push and i don't really want it blowing hot air into the case. Will pull be ok???
It will be fine
Halfords sell deionised which is just as good as the mayhems stuff
inb4 mlwood![]()
