Permabanned
- 15 Sep 2010
errrrrrr that statement is just WRONG![]()
Chill out man.
Now, the question is, why did AMD do this? TDP = absolute rubbish. Perhaps they were worried about longevity at higher clocks. Maybe they thought their PCB design is crap. Maybe maybe whatever whatever.
Reminds me when I was a kid, seeing who had the most pubic hairs.
I dont remember doing that lol. Must be something that only happened where you grew up.
I don't believe it was for reasons of power draw either. For example, Hard|OCP showed that, at stock volts, increasing the card to 1125Mhz came with an increase in power draw of only 24W! A 22% increase in clockspeed for a 10% increase in power draw certainly suggests that the chip is clocked below the power-performance "sweet-spot" at stock.
As for why AMD chose stock clocks of 925Mhz... Well there are certainly a number of technical reasons why AMD may have been uncomfortable running at 1Ghz+ on TSMCs new 28nm process. But this seems unlikely, given how easily 7970s are hitting 1100Mhz on stock clocks. I strongly suspect that 925Mhz was chosen in order to allow AMD to follow up with a higher-clocked part to compete with Kepler.
It's also telling that we haven't seen any manufacturer-overclocked 7970s with clockspeeds greater than 1Ghz, when we know full well that must are capable of hitting 1100Mhz+ without any voltage increase. I suspect that AMD want to limit the core frequency of 7970 card, so as not to encroach on the territory of the higher-clocked "7980" when it arrives.
Apparently the HD7980 with the new Hyperlane geometry is being released at the end of April a leaked AMD factsheet has just been published online.
Interesting... got a link?
Nah, it's top secret...
Believe it or not, the overwhelming majority of CPU owners never overclock. Intel simply released the processors at a speed that was 100% reliable, energy efficient, beat the opposition comprehensively, and allowed room for future faster refreshes without additional development cost to them. They can effectively release a slightly faster variant every few months without having to cut prices.Intel didn't release the I5 2500K with a stock clock of 4.6ghz but these chips easily clock to this on air. did they mess up also?
You are not the majority. Most CPU's are never overclocked. The majority of people buy pre-built PC's that are never overclocked, because most people don't even know how. Businesses do not overclock either. I cannot find exact figures, but I will be very surprised if more than 10% of Intel/AMD CPU's made ever operate at anything other than stock speeds. Overclockers tend to be computer savvy geeks who build their own systems and spend too little timPPe playing with real friends (probably a bit of a sweeping generalisation there, but also reasonably accurate). I know many people that use computers, but very few who can build one or even install an operating system. Most cannot even upgrade a hard disk or graphics card.I don't.
I've always lived by the philosophy that I should really buy what it is I want, and not something less and then try and make it into what I want.
PCs are no exception. If I have to overclock something to make it do what I want it to do natively I would rather pass and save up some more money.
You are not the majority. Most CPU's are never overclocked. The majority of people buy pre-built PC's that are never overclocked, because most people don't even know how. Businesses do not overclock either. I cannot find exact figures, but I will be very surprised if more than 10% of Intel/AMD CPU's made ever operate at anything other than stock speeds. Overclockers tend to be computer savvy geeks who build their own systems and spend too little time playing with real friends (probably a bit of a sweeping generalisation there, but also reasonably accurate). I know many people that use computers, but very few who can build one or even install an operating system. Most cannot even upgrade a hard disk or graphics card.
I see my confusion.Did you read the post you quoted at all, he says specifically he doesn't overclock?
English is not my first language (German is), and sometimes I take things in the wrong context. I must take more time before responding, and read comments fully. My English is not so good as I sometimes believe it to be[/B]
I don't.
- With a single GTX 285, 80% of the time a stock I7 920 would suffice as long as you are playing at at least 1680 X 1050 resolution. In 20% of the scenarios increasing the frequency to around 3.2 GHZ will yield gains in the minimum FPS at sub 1920 X 1200 resolutions.
- With dual SLI you would look to overclock your CPU at pretty much any resolution you play at. At 1680 X 1050 3.8 GHZ is recommended as a minimum. 1920 X 1200 is typically more forgiving for the CPU and a minimum of 3.6 GHZ is what you should be looking at. At 2560 X 1600, you could get decent gaming experience in most games at around 3.4 GHZ.
- When running Tri SLI, you will run into major CPU bottlenecks in most gaming titles, regardless of the resolution you are playing at, unless you have significantly overclocked your CPU. At 2560 X 1600, a minimum of 3.8 GHZ is recommended, and below 2560 X 1600, I wouldn't go with anything less than 4.0 GHZ.
Reminds me of this
