Thermal Compound
Interesting.....
My personal experience:
Thermal pads = poo
AS5 = Good, spreads easily - does the job
IC D = meh - overhyped, hard to spread and sticks like glue! - I got poor temps (worse than AS5) last time I tried it. Was gunna chuck the tube in the bin the other day lol. Oh and its quite abrasive so easily marks your CPU. Wouldn't dare use it directly on a GFX core!
Got a tube of MX-4 for my graphics (non conductive) seems to do the job well enough too.
I'll rank them,
CF3 - Hear good stuff about this.
AS5 - All time favorite, but conductive.
MX-4 - Great stuff and safe to use anywhere.
IC Diamond products dont even get a look in, even when they are given to me free.
Didn't see this thread and used AS5 for my new 2500k build yesterday, what problems could i have with it being conductive?
Interesting.....
Thermal pads = poo
I don't know because they're still going good on my x1950xtx from December 2006. Fully dusted. Still same temperatures as the day it was installed.
I'm not really noticing a great deal of difference between Arctic Silver 5 and IC Diamond on the Playstation 3. But saying that it's never overheating between either. Uncharted 2/3 sends the fan into full speed with both pastes but spins up/down in cycles just with that game.
I did notice Arctic Silver 5 had rub off all the print from the Cell and RSX. Only way to see it is like a hologram. Move it so the light hits it. ¬_¬
I always use the (Arctic Silver ArctiClean Thermal Material Remover and Surface Purifier) kit when cleaning. Though it never seemed to rub off the print on the AMD 64 chips.
Impressive the cooling on the Gelid Tranquillo for a s939 x2 90nm CPU with IC Diamond. 20c room temperature, case temperature can range from 27 - 31 while the CPU idles between 30 - 32c. 36/37c with Youtube streaming and prime 45 - 49c.
Though I really like Shin-Etsu on the x6 from my findings. I'd like to know what Corsair are using on their H80/100's. As it was Shin-Etsu they use to use on their past coolers so I had to buy a tube. I'd love to try the new stuff on the H70.
none as long as you are carefull, i imagine it could short out your motherboard if it got smeared where it shouldn't.
On a hardware enthusiast forum, and this is a problem? nowadays here this isn't the same place it was back in 2003. So many people were so eager to experiment and not close minded. But the past few years I can't help notice this serious dislike for Arctic Silver 5 now as if it had some disease or unnamed brand paste and it's made out to be 10/20 degrees out of everything else.
Now it's like soon as someone says conductive, it's a bomb. Run Forrest!
Is taking care and being thorough such a problem with most? It's not a water pistol.
i never said anything was a problem mate , only answered the guys question regarding AS5 , which may i add im using just now ;), anyway enthusiast forums no matter what the subject are here to help all no matter what lvl of experience the forum member has.:) (not realy sure whether this is a windup or not its only artic silver after all)) edit, just an after thought, maybe the forum went down hill when i joined in 2004 ? :)
To be honest it's rather difficult to fairly quantify minute differences between all the mentioned very well performing choices, I'd imagine little quirks during application and unique specifics of how well the compounds bond and settle each time are enough to invalidate small temp disparities as valid points of comparison.
I agree, any well-applied TIM will outperform a supposedly better TIM if its poorly applied.
Tinting both surfaces, a pea-sized blob in the middle & even pressure when mounting without lifting the cooler back off gives me the best results, which in my case during a pretty extensive test was half a degree difference between ICD & AS5
Ahh i bought AS5 as it was the cheapest as it was bundled with the i5 2500k i bought.
Im kinda nervouse about using it now due to the conductive properties, is it just a case of being extra careful when applying and not using to much?
I really wouldnt worry. The metal package containing the processor is designed to sit tightly against a big metal cooler, they aren't supposed to be insulated from each other, in fact quite the opposite.
If you go way overboard & some TIM managed to get in amongst the pins I imagine any compound capacitive or not is going to bugger up the system.
You've bought one of the best (IMO) thermal compounds available & your cpu is a fantastic overclocker, take some time to read the AS5 application guide & fit your cooler following their instructions:
http://www.arcticsilver.com/pdf/appmeth/int/vl/intel_app_method_vertical_line_v1.1.pdf
Is there much difference between mx-3 and mx-4? As some people say they prefer the mx-3 then the mx-4, I though the newist would be better.
Interested to hear views on this.. I've got a tube of both and I'm about to install my new CPU & tranquilo tonight.. or I could just use the stuff that came with the tranquilo...
