Apple wants all the 28nm wafers? Don't they use Intel cpu's and AMD gpu's in desktops and powervr in mobiles?
That would be true except, they both designed and built a card capable of far higher speeds..... errm, which suggests it was both designed and most definately built for faster speeds.
here's a hint, if it wasn't built to run at 1200Mhz +, it couldn't, it wouldn't have VRM's more than overspecced for such speeds, it wouldn't have a cooler capable of dealing with those speeds, etc. Extra VRM's, or higher spec vrm's and a better cooler than it needs all add's cost, or reduces profit. It is unquestionably built to go faster, suggesting something else is daft.
As for not blaming AMD and the rolleyes, considering I errm... blamed AMD, you can point your eyes elsewhere thanks.
BTW,I added another rumour to the list!!
Summary of rumours in thread so far:
1.)The first Kepler models will be released in either late February,or late March/early April or June 2011
2.)It will be faster than an HD7970,as fast as an HD7970,slightly slower than an HD7970 or slightly faster than an HD7950
3.)It will be priced around the same level as a lower end GTX570 or higher end GTX560TI or priced higher
4.)It will either have additional hardware for PhysX or not
5.)It will have a higher TDP than an HD7950 or a lower one
6.)Nvidia is not worried about GCN or is worried about GCN
7.)The GPU being released first is meant to be smaller than the Tahiti GPU used in the HD7900 series
8.)Performance will vary wildly from one game to another. Benchmarks may not be indicative of performance.
How are the Overdrive limits for the HD7900 series?? AFAIK,with the HD5800 and HD6900 series overclocking was pretty nerfed until third party software supported them better.
	Unlocked CCC
snip
Hi Dave -I seem to remember that you have BF3. Would you mind benching BF3 multiplayer at that speed on Ultra settings?
Soooooo, Any more news on the 680 coming in 4 weeks?
Been playing with FRAPS running since day 1 of owning card, and since the 2nd driver update from AMD i'm getting 90-110fps on Ultra all settings maxxed 1920x1080 at 1150/1650 @1.25v. Running with vsync on at 60fps there are no framerate drops, even on 64 player servers. Will run a 90sec benchmark in FRAPS later tonight as off out to a client now.
The problems with ridiculous framerate drops are non optimised drivers for crossfire 79** cards, which will be addressed on the unified driver 11.13
Don't know whether to wait for Kepler :/
I would, even if you're not going to buy one it can only serve to drive down AMD pricing.
The new drivers have really surpised me in BF3. I gained around 10% at 3560x1920 over the 11.12 "Disc" drivers. My card is now sitting at around 75% faster than a HD6970 at the same settings (before it was roughly 60%).
You're assuming Nvidia price match AMD, rather than doing what AMD have just done and price higher performing cards higher
