Sky HD channels - numbers?
Caporegime
6 Dec 2005
Birmingham
Does anyone know of a way to change what channel is what number?
Like having BBC One HD as 101, instead of 143, and ITV HD as 103 etc etc?
would like to know this myself, although I have seen on somebody elses box that BBC HD Sky Living HD etc was on 101, 107 etc respectively, although they do have a HD subscription
Nope!
They are fixed.:mad:
Blame OFCOMs, it's code of practice, Sky would fall foul of the current EPG regulations.
Only way I get around it by using favourites, your question has been raised many times before on the sky forums over the years.
Sky did ask channel owners if they wanted to move.their HD channels to take prominence over their SD versions and many did so, such as ITV 2, 3 & 4 HD but BBC one HD declined due to the number of regional variations amd local news not being shown on BBC HD.
Uchhh so that's a no then. That sucks because even though I've got them set on favs it's still a bit of a pain.
Freesat also doesn't let you re-order channels. Only Freeview does, AFAIK, and even that isn't possible on all set top boxes. Obviously if you have an HTPC you can do what you like - I have channels 1-5 as BBC One HD, BBC Two, BBC Three, BBC Four and BBC HD.
Nope!
thats a bit ****, if you own the box you should be able to choose what is where
I was just about to say "just save them as favs" IIRC, you can select which channel you actually want to display so you could just replace SD with the HD ones, It's in the settings somewhere
This is why Sky changed all the HD channels round with their SD versions.
So Sky 1 HD became 106 etc.. because some people are just too lazy to find the right HD station and just watch it in SD instead.
yeah - i know that but you can't record it or pause it using that method. It's pathetic really
Fair point. I only use it whenever there's a football match on ITV. The difference in the SD and HD feeds is massive.
Also, the wife says that some people shouldn't be shown in HD (shows like Emmerdale and Coronation St.) so maybe its a good thing :D
Same on my Sony TV with FreeviewHD built in, if I want to watch BBC, ITV or Ch4 in HD I have to remember to go up into the 50's to find em!!..
s'bloody annoying!!
Thread bump :D after 5 months of having my sky box reconnected ive only now noticed bbc2 wales isn't in HD on channel 102..... They still dont let you swap channels around.. grrr
