I made the post elsewhere originally but thought i might get good response here too, http://forums.overclockers.co.uk/showthread.php?t=18373069.
Thanks
Thanks
I cloned recently and whilst I was able to boot up ok, the ssd alignment was incorrect. If you're going to clone, make sure you read up on ssd alignment. Not all cloning software correctly aligns the HD.
In the end it was just easier to do a clean format which I'm glad I did.
Humm, will prob go for clean install then... wanted to be a little lazy but looks like it's better to put the effort in and avoid problems further down the line.
No my plan was to do a fresh install and then restore parts from a backup. Just wondering how much i can backup? user files is easy, but what about installed programs?
Fomating & installing windows......what else is there to do on a sundaymmmk, looks like my sunday is now occupied. Thanks for the assistance
Fomating & installing windows......what else is there to do on a sunday![]()
