- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Enjoy a very enjoyable ambient experience with the new LED lighting targeted for installation behind your monitor, however you can use these inside your case, under your desk, your imagination is the only limit (oh and being able to power it via a USB port)
Antec Soundscience Halo 6 LED Bias Lighting Kit @ £9.98 inc VAT
The soundscience halo 6 LED bias lighting kit™ makes it easy to outfit your monitor with professional backlighting. Bias lighting is an illumination technique for reducing eye fatigue and increasing perceived image clarity during long gaming sessions and extended periods of computer use. The halo 6 LED bias lighting kit™ adds a subtle white backlight to your monitor, reducing the eyestrain caused by differences in picture brightness from scene changes in movies, TV shows and video games. The color and brightness of the LEDs are carefully calibrated to achieve the optimal viewing experience. Bias lighting also increases your monitor’s perceived contrast ratio – making blacks blacker and colors more vibrant. Installation is easy – simply attach the LED strip to the back of your monitor and insert the USB plug into an open USB port on your computer or powered USB hub. The soundscience halo 6 LED bias lighting kit™ complements any monitor up to 24” in size.
- Requirements: LCD monitor up to 24” in size placed against light colored wall; available USB port or powered USB hub
- Certifications/Safety: CE, RoHS
- Unit Dimensions: Cable: 1300 mm / Light Strip: 370 mm
- Net Weight: 1.0 oz / 28.3 g
- Product Warranty: 2 year
Only £9.98 inc VAT.
ORDER NOW
Only £9.98 inc VAT.
ORDER NOW
