i cannot seem to snag any gpu tasks,
Scuttlebut has it that we're in a shorty storm for S@H; stuff is being turned around very quickly by those lucky enough to get work hence the pipes being maxed out.
Well I bought some more ram so I guess I will crunch some more.![]()
Ahh not to worry it'll work out with seti sooner rather than later i hope.
Me and multiple virtual machines do not get along, before i started tinkering my first t4t task completed in 24 hours the next one "stuck" at 65 percent then the next at 33 percent grrrrrr ..... will leave it and try again tommorrow![]()
T4T tasks should run for 24 hours. If you have a task that has run for more than 24 hours you should not abort it. Use the procedure below to end the task nicely so that you receive credit for it. The task will receive extra credits for the extra time it has run.
This method can be used to terminate any T4T task nicely, for any reason, rather than aborting it. If you abort you don't receive credit; if you terminate using the method below you will receive credit.
There are 2 ways to do this. The command line method is easier and faster but requires use of the command line and the GUI method which is more involved and takes longer.
Command line method
1) In BOINC manager, highlight the T4T task (click on it) then click Properties, in the list of properties there will be an item named Directory and it will be "slots/X" where X is some number, remember that number.
2) Open a command prompt (terminal in Linux and OS X), enter
echo 86400 > "{path to BOINC data directory}/slots/X/ProgressFile"
where X is the slot directory name you found in step 1. The {path to BOINC data directory} is in the BOINC Event Log about 5 to 10 lines from the top. If the path has any spaces in it you must enclose the entire path in quotes as shown in the example above. If the path does not have spaces then the quotes may be omitted. Type 86400, not 86,400.
3) BOINC_VM should shutdown within a few seconds and the T4T task should complete normally and go to "Ready to report" status.
GUI method
1) in BOINC manager suspend the T4T task, the VM should then say Paused, if it doesn't say Paused then this won't work (you might have to wait a few seconds for it to go to paused state)
2) highlight the T4T task (click on it) then click Properties, in the list of properties there will be an item named Directory and it will be "slots/X" where X is some number, remember that number
3) open your BOINC data folder, open the slots folder and look for the folder named X (not X but the number X), open that folder
4) in the X folder find the file named ProgressFile, open it with Notepad, DO NOT open it with Word, Wordpad or any other program, open only with Notepad
5) in ProgressFile there will be a single line, delete that line and type in 86400, exactly 86400, don't put any commas in the number
6) save the file, close Notepad, doublecheck the file and make sure it's still named ProgressFile, if the name has changed then rename it to ProgressFile
7) back in BOINC manager, resume the suspended T4T task, it may then go to the "Waiting to run" state, if it does then suspend other tasks to force T4T task to run again, the VM should change from Paused to Running and run another 20 seconds or so then the T4T task should end normally and shutdown the VM.
8) if this procedure does not cause the T4T task to end you'll have to abort it
Welcome back sah, i think the pipes are blocked but congrats on the ram and getting your rig sorted![]()
erm *goes to find other project to do for a bit.
Great so no work then.erm *goes to find other project to do for a bit.
Early postie
Good work Derv. You are well beyond reach now. New baby (no not a rig) due in 6 days so i will be cutting down on the electric use at home. Also i have been told that a new pram is a priority over a GPU... which i think is a bit mean.
You'll have to post up a piccie of the litte'un when he arrives.
