Will this apply to Golf Plus?
I'm looking to buy a used Skoda Fabia VRS - would this model be effected (diesel VRS this is) ?
Steering column problem is a simple fix now of a new part in the ignition, it used to be an entire column replacement.
Yes the MK1 diesel VRS had the PD170 fitted, a mate of mine used to have one. Give Skoda a call and see what they say.
Mk1 Fabia vRS was the PD130 not PD170, would this still be affected?
That's so wrong words fail me.
Little bit OTT don't you think?! Was grabbing a quick shifty of the forums while at work and in my haste I misread it as an Octavia vRS, which of course was fitted with the PD170..my mistake.
How much did it cost?
And for anyone who cares, the 140hp and the 170hp engines do indeed use different injectors (170's are now fitted with part # ending in t, and the 140's are now fitted with part # ending in S)
Any questions just ask!
Is it only VW that are affected, or are Seat/ Skoda / Audi equivelents affected too? I have a 57 plate A6 2.0TDi 140 for example.
Thx
My parents have a Golf 2ltr Diesel. No idea what year but I would guess about 07. Any chance this is affected?
Column used to be £1200 + Fitting + VAT
part is approx £50. I think the coding has to be done at main dealer as it is something to do with the computers as the factory. Local VW specialist took ours over to the dealer as he couldn't do it.
