- 28 May 2007
Well, in quadfire@5760x1080, managed... and temps were toasty on default settings highest hitting 95C then the fans really kicked in...
Quadfire v's Trifire... 18% improvement in average fps and 10% improvement in maximum fps. Certainly not the scaling you got from single > dual > tri 6970's... proving drivers are just crud on quadfire.
If you still have the same pc in your sig then i would imagine your a cpu bottlenecked. Quadfire needs lots of cpu horsepower and a q6600 at 3.4ghz will not cut it. I dont think its even enough for xfire never mind quadfire. Even though your running at a very high res i would still say your cpu is not gonna make 4 gpus scale well.
