Isn't Gliptone quite highly rated for rejuvinating leather too?
Quick question, what sponge/cloth would you guys suggest to use?
Its not really a detailing kit as such, more of a clay kit with a sample bottle of Super Resin Polish.
I've never used the AG Kit, always used the Meguiars Smooth Clay Kit. Works well, the wax supplied smells great and leave a nice finish too!
There are two versions of the Megs kit, one is the "Quik Clay" (Clay & Lubricant) and the other is the "Smooth" kit (Clay x2, Lube, Wax, MF Cloth). You can get them for £20ish delivered on eBay or Amazon![]()
I've got both Gliptone cleaner and conditioner and it's awesome.
Probably doesn't smell as good as the Zaino though. It's definitely a bit 'funky'.
For doing what specifically?
The general rule of thumb is save your sponges for doing the dishes because they drag dirt across your paintwork and scratch it.
To wash the car you want a mitt of some description; lambs wool is my weapon of choice.
To dry the car you want a waffle-weave or deep-pile drying towel as these will reduce the amount of contaminates you drag across the paintwork.
To apply polish/waxes/sealants, there are specialist applicator pads and to remove them it's best to use a microfiber cloth.
And you thought it was going to be a quick question!
