LARP vs COSPLAY
Several, I dress them in cosplay and make them larp
Aww, You upset that I didn't play into your 'I'm gonna pick apart your answer with my superior wit' game?
Answer 1: Yes I own a sex doll
Your reply :lolpatronisingandjudgementalanswer
Answer 2: No I dont own a sex doll
Your reply: ohwhynotisitbecauseyourejudgementalofthepeoplethatdohaveonelololol
I went for secret Answer 3: brush off the conversation with you and go watch an episode of fringe. it was a good one, They're just digging up the end of the world device called the vacuum, although i secretly suspect it's going to open a constant portal between realities, rather than end the world right away.
e :I like your comment more than your argument. Her name is 'Charlie', isn't it?
e2 : I'M BEING JUDGEMENTAL!
Don't understand the realdolls. I don't think I could have sex with something that doesn't clean itself automatically afterwards. :/
That sounds like an opening in the market to me!
I have no problem with either Cosplay or LARP. Althrough i hear that the girls that Cosplay (the fit ones that tend to get there pictures posted anyway) are right attention whores and rather bitchy
Lets just be perfectly honest here. We're not interested in them for their personalities ;)
I just have images of people running away from you after sex and cleaning vigorously.
What do you do to them!?
Well if you're not wearing a hat, then there tends to be a bit of dribble aterwards which can make things a bit messy. Obvious, I'd have thought? :p
