Several, I dress them in cosplay and make them larp
Aww, You upset that I didn't play into your 'I'm gonna pick apart your answer with my superior wit' game?
Answer 1: Yes I own a sex doll
Your reply :lolpatronisingandjudgementalanswer
Answer 2: No I dont own a sex doll
Your reply: ohwhynotisitbecauseyourejudgementalofthepeoplethatdohaveonelololol
I went for secret Answer 3: brush off the conversation with you and go watch an episode of fringe. it was a good one, They're just digging up the end of the world device called the vacuum, although i secretly suspect it's going to open a constant portal between realities, rather than end the world right away.
[FnG]magnolia;21284876 said:I'M BEING JUDGEMENTAL!
Don't understand the realdolls. I don't think I could have sex with something that doesn't clean itself automatically afterwards. :/
I have no problem with either Cosplay or LARP. Althrough i hear that the girls that Cosplay (the fit ones that tend to get there pictures posted anyway) are right attention whores and rather bitchy
I just have images of people running away from you after sex and cleaning vigorously.
What do you do to them!?
Well if you're not wearing a hat, then there tends to be a bit of dribble aterwards which can make things a bit messy. Obvious, I'd have thought?![]()
Nope, they swallow for me.![]()
