Rigs are size-graded now so they're actually quite reasonably priced. You're no longer paying the same for a trimark on a BS as on a frig.
It's actually gotten to the point where I will T2 damage / ambit rig T2/faction hulls more or less as standard. They're not the big money items of yesteryear. Slapping T1 damage rigs on a ship adds very little to the cost.
Some rigs (CDFE, Trimark) may well cost more than a T1 hull but then probably so will T2 modules and faction ammo so meh. That's just kind of how the maths works out with cheap hulls.
Unless you're making a total junkfit I'd say you basically always want to rig.
In PVP most stuff is now rigged so you want it to stay competitive. It's such a no brainer sticking HP rigs on, most people do.
On a PVE ship it depends on the fit but they are such a boost for some fits. For passive shield tanking they're the difference between rubbish and awesome.
Wouldn't bother with them on that rax (isn't that the exact same fit as before? Same advice as I posted before counts. I'd only add you don't need to train a skill to remove modules) but generally.
