Tried to find an update but couldn't see any new bios versions.
Current BIOS version running 0706 (08162011)
Looks like it must be a software issue. Can't imagine that 2 cards would fail in the same way.
Hey peeps
Reboots under load, but runs fine on desktop and whilst using the the low powered onboard GPU? Sounds more like a hardware issue rather than software, especially seeing as you seem to have done the basics - ie updating BIOS, drivers etc.
To the OP, Have you run a high end GPU on that PSU before? have you got access to another PSU? that would be the first thing I'd try.
Hey peeps (especially Darrensen for taking up the case) - thanks for all this so far. It is my machine - and to fill in a bit more detail: I ordered a Rev B3, but the ASUS AI Suite shows Rev 1.xx (exactly as this) with 0706 BIOS installed - I have updated this to 0902 BIOS as indicated on ASUS site (where 0403 BIOS is also given as an option) for non Gen 3 (Gen 3 indicated 0402 BIOS).
Great, thanks chaps - the PSU and GPU are both brand new - PSU is Antec 750W "High Current Pro," which had good reviews - you guys might know different?
Darrensen has lent me a working PSU - only 450W but I will connect just the minimum
I think one of the few 'advantages' of the GEN3 models is that they have a 'built in' USB 3.0 connector on the board... which is probably not of too much interest to you anyway!
Did you try removing any overclock on other parts?
If you where GPU bottlenecked before the upgrade, then after it the CPU would be put under more stress in 3D applications and the overclock might not be stable any more.
Take the motherboard out and check for brass or black mounting posts in the wrong place. Common error. This can cause a short.
Check the CPU cooler is mounted properly and that any rubber grommets or washers or rubber pads are in the correct position. I watched a guy kill three motherboards before realising he had not put the rubber X pad in the back plate of his Noctua cooler.
Take the CPU out of the socket and check for bent pins in the motherboard. Again, two pins touching will short and cause memory related issues (incorrect size being reported) and reboots. Failure to check this could end up in burnt shiny areas of the CPU contacts and ruin the CPU.
Those are the most common user errors I can think of. Not being rude or anything but PC problems?
5% software.
2% hardware.
93% user error.
Thanks for all, good people - it WAS the PSU - a brand new Antec 750W "High Current Pro" which will have to go back for replacement. I supposed it would be the least likely part to be faulty - some of you guys put me right on that one.
Thanks once again to all who took an interest and made this a better experience than it might have been without your help.
