Who here owns a Renaultsport?
I don't really struggle - they feel a bit small with my steels on, but not particularly a problem.
If you want pedal problems, try driving a Corsa B.
I've got size 12 feet and I really quite like the pedal positioning, apart from when I have to reverse... I have to use the very tip of my foot so I don't hit what I think is the steering rack :p
Guys, i got a couple of lights that have come on today
i was driving home from work, about 10 mins drive, and 2 lights came on (not flashing, perminatly)
these are :
Toxic fume monitoring
warning light
and
Preheating/electronic
fault or water
in the diesel
warning light.
i copied and pasted from my manual, its a clio sport 2002
any ideas? Thanks
thanks guys
thinking back to my last service and MOT (had them done 2 weeks apart)
I had an advisory on the middle section and the exit one on the exhaust
wondering if that is why?
if it is a lamda sensor are they costly to buy?
As above, lambda's arent too expensive.
Just been onto CS and seen there is an artic blue 182 for £1750! Admittedly it needs a dephaser but its still cheap.
Serv and ESP light came on this morning on my way to work, couldn't turn the ESP light off either, no response from the button. Got to work, switched off and back on and the lights weren't on.
Could be related to the brake pedal sensor that needs resetting?
I had this exact same problem a couple of weeks ago, my ABS light was on too
Mine lights turned themselves off on the next journey and haven't come on again since, except when they are meant to of course
Not much help but at least you are not alone!
Going to need new brake pads on my 197 (getting them fitted before the end of next month when I get my car MOT'd) - any recommendations on pads and suppliers?
