bundymania do you have shares or possibly own Bitspower? That is a lot of sexy fittings.![]()
Or adding onto this are you perhaps like partnered?
mmmmmmmmmmmmmmmm goldthere should be white bitspower fittings
also show some pics of the rig that only uses fittings? that is, if you have pics![]()
thanks bundyboth look awesome, how's your watercooled r3 coming along?
bundymania that is definately a lot of fittings!!! Those red fittings look nice though, were they some special fittings or did you get them done yourself from the normal nickel ones?
One of many mental notes for ideas come any future builds, I think blue compressions with clear tubing and white fluid would the nuts.
