Personally, I would reset it back to stock speeds until you get a new cooler, since 86 degrees after only a few minutes at 100% load is really too hot. Also, I wouldn't recommend running the BLCK at anything other than 100MHz.
True, I will reset after work tomorrow.
How do you mean you wouldn't recommend running BLCK at anything other than 100mhz? Sorry nooob here
