i would wait
i know its getting long in the tooth now saying wait but why dump so much on a 7970 when nvidia will be beating it buy a minimum of 10% and thats without listning to any roumours
Source?
come off it, nvidia have bettered every card they bring out by 10% and usualy 60%+ with an architecture change, the 7970 barley beats a gtx 580 in bf3 with aa
I was being concervative with 10% if im honest
Thanks guys, would a 2700k be fine or should I upgrade? I want something which will play games maxed for around 1-2 years.
No matter how likely, you simply can not state it as a fact until it actually is because **** happens, even i think that NV may scrape through to top spot.
Nvidia are on the ropes, they're done for, don't expect miracles, expect a poor card for muchos $$$$. 1st Kepler will only just beat a 7950, nothing to beat a 7970 until at least Q3. And lol, you clearly know FA about 7970's on BF3.
the 7970 is a failure, look at it, its 1 year old tech at new tech money. its 4fps in bf3 better than a 580 @ my res. Great stuff
It seems its you that knows exatly fa about these things dave.
Unless of course you mean with aa off but then why would i want a 7970 to play with aa off?
For the 7970 to be a good card it needed to be £350@ launch and £300 now but it isnt
thats why i was saying 10% not the ususal 60%
ive looked a lot at whats happening with gpu's over the past few years i know what happens with a 7970 in bf3
up to £600 per card.
Shut up. If that is really your budget then why do you need to come here. Common sense would dictate that at that budget you'd just buy the most expensive card available times 2 knowing that would do all you ask. After all your asking for multiple monitor support on one of the most demadnig games aailable and wanting two years future proof. Everyone knows a 560Ti isnt going to come close or a 570 or even a 580 so you didnt need to come showing off
