Caporegime
- 7 Apr 2008
- Lorville - Hurston
tempting but will a 800w corsair module psu be enough to run two 480gtx, a 920 and a bunch of hdd's?
Nope. Two 480s are 850W minimum, even that I'd call a tight squeeze..
kd
Rubbish, decent 750W is fine with a 920 D0 @ 4GHz. Ran mine for well over a year at that, never came close to maxing the PSU out. That 800W unit you have jonneymendoza will be fine.
cheers. dont forget, i got a water cooling loop as well mate. ssd2 and 2 sata hdd's one dvd drive and about 8 120mm case fans hosued inside teh case/triple rad.
my 920 is cloked at 4ghz and my single 480gtx at 900mhz something like that
How hard is it to find waterblocks for these things?
I already have one 480 and im thinking SLI will be better than upgrading to kepler.
Got my ASUS one running at 580 stock clocks with modded bios so it is cooler and quieter just like the 570 but with more VRAMTRUST ME GET THIS CARD!
Runs on stock cooling and never goes above 80c on loads which i think for a 480 is AS COLD AS ICE
hmmm you got me thinking... do you mind pointing me in the right direction with the modded bios, and is it easy to do it? cheers
Hmm, I'm ordering one of these today along with a bunch of other components. Does anyone know; if I order this (as it's on pre-order) will shipping for all my order be delayed until this card arrives, or will I be better off making two orders and paying for shipping twice?
Ideally need to order today, is all.
No your order should not be delayed and they will send the card out on its own once in stock.
