[BitFenix] Support and Discussion Thread!
Ah, so does the 360 in the roof.
Realistically looks like you can't really get away with 360 in front and top because you'd have nowhere to stick hdds.... Even if you didn't need optical drives...
Guessing there's no bottom on the optical drives so it slots in easy?
kd
Thank you xbournex for getting back. I'll keep an eye out for that. Will it be compatible with the 12v Alchemy LED strips?
You'll have 1 5.25" so an adaptor would work.
Then the 30cm in the back will fit a couple of SSD's with the use of double sided tape.
dj: I have no information yet on the final product, so you're best bet would be to wait. - Since it is a BitFenix product, I can't see why it won't be compatible.
luvly jubly! I'll wait for that then :) Really nice to see you guys are listening to us and producing great quality products!
Right i'm off to stick my Spectre pro Fans in! :)
Yeah SSDs can be mounted anywhere which is nice :) Must say, in future case designs it would be nice if with such a large back gap you could create some simple 2.5" Screw holes for mounting. :)
Going to have to think about WC options. You got any to measure up yet? :)
Thinking I might have to reduce down to 3 240's... Although that will happily support CPU and SLI.... Saying that might have to wait until summer to buy it for the cost!
kd
Is that only 75mm at top.... Not quite enough for fan + 60mm... Bit of a shame if true. The extra 15mm would have been useful....
Definitely going to need to measure one of these up myself, or wait until someone makes a sketch up model mm perfect :s
kd
Included. Earliest I can say is the 9th. (that's if everything goes smoothly with those shipping companies.)
12 is safe date..
Just ordered my Stealth bay for an XL. Bit early I know, but OcUK were low on stock, and I didn't want to risk them being a discontinued accessory and me not getting one :)
Looking at the Switch 810 Review at the moment... Still thinking the Shinobi XL is the better case. Might need a bit more modding. But it just doesn't look anywhere near as cheap and frail....
kd
Ah a Bit Fenix rep... awesome! (hopefully)
When will OcUK get the Spectre Blue LED 120mm fans on... they do every other colour than the blue.
I also use the Shinobi Windowed case and all my fans apart from two are the 120mm blue led spectres.
Any chances of getting them on here???
